Anyone use an IDA-X001 with PXA-H701 ??
Understood. Ok so for full control, gotta use the controller..
This unit will "connect" to the H701, I guess via AInet (analog).
I was wondering if anyone that had done this.. how'd it sound vs going fiberoptic with a DVD unit?
I'd bet it wouldn't work.. If a guy could get an optic digi-out from the thing, $50 says there's probably some proprietary stuff in the signal the H701 might be expecting... Man if someone tried and it worked.. I'd be sending them one to mod in a heartbeat.
WOW, I thought it was a 'remote' kind of controller! ouch! Price isn't too bad, at least what you could theoretically get it for...but a custom install is in order...hmmm....glove box, custom mount panel, custom installed iPod next to it...hmmmmmmmmmmmmmmmm
the c701 controller is about the same size as an HU's faceplate, width & depth, so it can be fairly easy to mount somewhere other than in an available din spot.
an h701 the heart of my system.
I have the H701 mounted in the din area above my asktray in my Mazda3, looks good. Made a custom mount panel.
Pretty cool.. I can't tell the model number of head unit you're using.. I'd guess you're running optical to the 701. If you are not running optical but analog, how is it?
Babs
Babs
NC
onefastsi
