Anyone run 1/0 in a G6?
97chameleonbird
Planning on running some 1/0 in my 07 G6 Coupe. I would rather not pull seats but doubt it will fit under the door sill. Anyone know if it will fit or an alternate route in running it? If I must pull a seat I could probably do the passenger side because its not electric on that side. Thanks.
I run all my power wires outside the car....inside the frame rails and loop
them into the trunk and or hatch areas.......unless its small wire and I can find a hole
in the firewall
Comes out cleaner IMO outside routing.
I was referring more to the sleeve
Battery Cables use cheap sleeves and they last for decades,Car Audio cable use thick durable
sleeving......Its a non issue - I have my KNU 1/0 cable under my truck 6-7 years
and its been fine.......//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Battery Cables use cheap sleeves and they last for decades,Car Audio cable use thick durable sleeving......Its a non issue - I have my KNU 1/0 cable under my truck 6-7 years
Where do you live? Do you drive in salt and snow? How do you hold it up with rubber insulated clamps bolted to the underbody?
How do you end up getting it back in the car, do you have a couple of quick pictures? Thank you.
Also, the G6 has the battery under the hood. I was thinking of putting it in the trunk but I would have to run wire to the rear then anyway.
97chameleonbird
97chameleonbird
Boston, MA
97chameleonbird
