anyone know if the dakota has a reg outside the alt
OLD_SCHOOL
i was looking at doing a big 3 upgrade on my 2003 dak mostly because i am at stoping point in my install waiting on my subs and saw that my alt wire goes to the under hood fuse box wondering if the regulator is there on on the alt cause that would be some problems if i run off the alt straight to the battery
thats how my g/f van is. the wire goes into the fuse box to feed the box, and maybe fused too. but i'm pretty sure that all newer carshave internal regulators. if still in doubt call the parts store in the morning and ask them.
if you have some spare wire just run it from the alt to the batt.
disconnect the "factory" wiring and start your truck up.
Look at the voltage, if it stays at 12v then it has an external regulator.
if it bumps up to 14.4v then its internal and your fine with the big 3.
(i did this with my burb)
if you have some spare wire just run it from the alt to the batt.disconnect the "factory" wiring and start your truck up.
if it runs into a fuse box, and he cuts the box out of the circuit the truck might not run, because most of the time the relays under the hood are for vital engine functions, ie. fuel pump, fans, sensors, etc. . . please if you do this, use caution.
//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif don't listen to supa c. . . he dont even have a car, he hauls all his stereo sh!t around behind his bike! j/k!hehehe //content.invisioncic.com/y282845/emoticons/offwall.gif.29a91b9b265d47af4b8e33fc5b558d18.gif
OLD_SCHOOL
OLD_SCHOOL
Buford, Ga. Metro ATL
supa_c
