anyone have test results for a3000db vs bamf5500d?
ktraughb
as the heading says. just wondering if anyone has any real-world test results for these amps. i know for sure ive seen that the 3000db can realistically produce about 2000 watts at 14 volts, but havent seen much on the bamf series. i notice it has on-board fusing (200 amps). if it can make use of that it very well could be capable of 2k. just wondering because theyre pretty cheap, and i see a couple forum members have them.
The 3000db is prolli one of the better "cheap" amps ive ever seen. Also they aren't too much of a current hog like alot of these "high power" cheap brands are.
I pretty sure the bamf5500d has the same board as the Kole 5500, if so it does put out sum decent power but is quite the current *****.
yeah i would assume the 5500d is the same as the kole (i know last years model was). the only difference i see with this new bamf series is the layout of the board as to where the terminals are. i assume the kole has on-board fusing, but not sure if it matches the 200 amps on the bamf amp.
yeah the hifonics amps are always a good budget amp to fall back on for good rated power. but of course the 10 series is still gonna be a little expensive in comparison to what you can the PA amp for, especially considering the pa amps are a year older.
ktraughb
ktraughb
Louisville, ky
ktraughb
