Q-Factor Control of Lowpass Filter: QFC allows a control of the lowpass filter slope; basically turning the QFC potentiometer will change the damping quality. Depending on the individual requirements, it is possible to give the subwoofer a "slimmer" or a "fatter" sound. [the setting is from 0.5 to 1.2]
basically controls how fast it cuts down the power above the lowpass setting
Q" is a measurement that usually comes up when talking about
equalizers. It tells how "wide" the affected area is when you dial in
boost or cut for a particular center frequency. For instance, in an
equalizer with a large "Q", if you dial in 3 dB of boost at 120 Hz,
you may find that this results in a 2 dB gain at 110 Hz and 130 Hz,
and a 1 dB gain at 100 Hz and 140 Hz. Also, in some equalizers, the
more boost or cut you dial in, the larger "Q" gets, which means that
if you need to dial in a large amount of boost or cut, like 6 dB or
more, you may get unwanted effects on nearby frequencies.
An equalizer with a smaller "Q" would allow you to dial in
larger adjustments without the changes spilling over into adjacent
bands as much. Several manufacturers, such as AudioControl, have
"constant-Q" equalizers, where the "width" of the affected frequencies
doesn't change, no matter how much boost or cut you dial in.
