anyone have a 4 door truck setup?
Ryde _Or_Die
I am thinking of purchasing a new dodge ram 4 door and have been thinking about a system for it since I put one in everything I drive. Now where can I put amps? I mean I need the room under the rear seat to try and build a big enough box for any kind of output. So what are people doing? I can't even find a decent 5-channel amp to push everything. Any ideas?
Ummmm
get good with FG and put the amp up on the ceiling and the subs under the back seat
OR
weld in a blowthrough and get a truck bed lid
OR
fabricate up some really leet front substage
OR
if it has buckets you can try for a center console 15
OR
if it has a front bench, put amp(s) under front bench and sub(s) under back bench
Think this is as good as it gets. Right now I am thinking L7s, probably 2 8s or 1 10 depending on space. Would be nice to find a 5 channel amp that puts out like 500+x 1 @ 2ohms and 75x4 @ 4ohms or similar.
i'll post pics of my CC Titan once done, 2 8"w7's, the amps are going on the back wall
I am putting 4 8" RE s behind my rear seat in my crew cab! But I have no clue how much space you have to work with behind your seat.
I looked into 5channel amps when I was thinking about one sub, but the cost of 5channel ampos could usually get you a nice mono and 4channel amp!
Well my father has the same truck as I'm getting and the back of the rear seat is attached directly to the back wall. At least up top. But there are options for different seats so I guess thats something I need to look into.
Ryde _Or_Die
Ryde _Or_Die
Tampa, FL
Ryde _Or_Die
