Anyone ground the HU twice?
butterMilk
BC
Wound there be any benefit of grounding the HU to the stock wiring harness, and then also grounding it to solid metal behind the dash somewhere. By just splicing the ground on the back of the HU. Maybe it would help reduce any chances of engine whine or static?
Some of the factory harnesses just wire into a common ground. This is the type that would give you noise, or sometimes clicking when various devices kick on.
If you have noise, then I would switch your ground from the harness ground to a dedicated ground to bare steel behind the dash.
Yeah theres not much mounting locations to chose from behind the HU (inside the dash) Guess I'll just have to run a long wire down to the floor somewhere.
butterMilk
butterMilk
BC
butterMilk
