Anyone experianced with a JL 12W0-4??
Ruffy
Death to the salad eaters
Reason being is I have one and plan on using it for a short while to tide me over.
Now I bought a aura amp off of Parts express
It's the Aura RPM2300
says it does 150rms x 2 @ 4ohms
or 450RMS Bridged Mono @ 4ohms
My quesion is how should I run the JL Sub? The PDF states that it's only around 125W RMS! So 150ww and only run one channel? or bridge it to 450
Now I know I can overdrive it past that. I just never heard of a 12" Sub with such a low peak power. My brother used the sub before with a Rockford fostage amp. I believe it was the P8002 but I'm not sure.
Amp is here
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=269-162&CFID=592836&CFTOKEN=15775291
PDF on the Sub is here
http://mobile.jlaudio.com/pdfs/10_12_15W0_MAN.pdf
According to the "chart" at the bottom, anything past 250watt is dangerous
side info
I tried running 100wrms off my Clarion APA450 amp. Sounded like ass but many factors could have caused this. Such as
1. I litterally cut the leads going to my rear 6x9's and jammed them into the speaker level inputs on the amp. It worked but not well
2. I dont know if the sealed enclosure that the sub is in was made to the spec of that woofer. It was "made" for my brother and his truck.
3. I used 1 channel of the 6x9's. So i had a sortof imbalance thing happening between the one that was still on and the sub.
4. Sub in the box were just laying on my backseat when I "tested" it.
Ruffy
Ruffy
Las Vegas, NV
Ruffy
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
