squeak9798
Banned
As I explained...if you only want to use the amplifier's xover (which is apparently 24db/oct), then you set the HU xover as high as it will go which will effectively push it ("it" being the HU's xover) out of the range that "matters".How whould I be able to use a 24db slope like what is offered on my amp. It is not adjustable on my amp.
Kinda sorta.I understand the crossover freq part but what about the HU 18db slope and then the amps 24db slope ?
That adds up to -42db slope @ 80hz
It ultimately depends on the type of filter, how they designate the "crossover point", etc etc.
But, for an easy example......lets say that everything is the same except for the slope and they both use the common designation of the crossover point as -3db. If you set them both to 80hz....then yes you would yield a -42db/oct slope and at 80hz the signal would be -6db down rather than -3db.
