Sold anybody intrested
You NEED one of those 15K's they look a lil like this
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
There not on their website anymore, but here...
Specifications e15K
Qts. .41
Qms. 5.7
Qes. .43
Fs. 23hz
Vas. 160 L
Sensitivity 91.1 dB
Re. 1.75 Per Coil
xMax 15.8 mm
BL Product 20
Sd 825
Magnet Weight 100oz
Displacement .085 CF
Cut - Out Diameter 14"
High Excursion Back Plate yes
Speaker Weight 19
Mounting Depth 7.2"
K - Series Power Chart
Mininum Rec. Power 75 Watts
Rec. RMS Power 400 Watts
Maximum RMS Power 900 Watts
This is a SPL/SQ driver. Very versatile!
Originally posted by neonak jezus...
healthy specs i would say
do u need the amp specs??
well here they are
BEtter Audio 1600M1 Amplifier
Class D Topology
Variable Subsonic Filter (15-40Hz)
Variable Low-Pass Crossover (50-250Hz)
HP Crossover Pre-Amp Outputs
Remote Gain Control (Included)
Phase Control
Clipping, Speaker Short and Thermal Overload Protection
Dimensions: 17" x 9-1/2" x 2"
Power Output:
500x1 @ 4ohms
1000x1 @ 2 ohms
1500x1 @ 1ohm
im betting itll do close to 1600 at 1ohm at 14 volts
1 of the 15's has the rattle that has occured on sum of the ED k series, thats one of the reason for the new k's, i have already sent one back and they fixed it, so 1 of the other 2 has the tinsel slap problem but i couldnt even notice it until i turned it all the sub then u could hear it but when u play ur highs with it u cant tell even, but if someone wants the sub ill send it back to be repaired but ill raise the price like 15$ b/c itll cost me 20 to send the sub back
abcdefg
abcdefg
Clarksville, Tn
pinkyd3
