yacob.naif
I've still been scouring partsexpress for components for a DIY setup, and i've been looking at a couple different drivers. The amplifier i'm using will give 120w rms @ 8 ohms, or 240w rms @ 4 ohms, CEA2006 certified, so either of these drivers will work fairly well with the amplifier.
can anyone tell me which (if either) of these speakers will work in an IB install?
Or at least what i should be looking at to pick better drivers?
I need something that will be comfortable playing down to 60hz infinite baffle, without the suspension wussing out and self-distructing, my substage is most likely going to be a pair of Dayton Reference series 15's in 2.5 cubes each.
Here's the two drivers i've been looking at. I can't afford morels, but i think these two speakers look like the best for my money.
They'll be playing 60hz-500hz, btw, in a 3-way configuration.
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=296-432
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=295-368
my midrange and tweeters are most likely going to be dayton reference as well, which is why the dayton reference 10 is in consideration, but the dvc ac woofer would make better use of my available 4 ohm power to bring the midbass home with some grunt.
Let me know whacha think.
