Sold any suggestions?
type r's can handle more than 500rms
If you wired the subs parallel you would get a .5 ohm impedance
(1/(1/2+1/2+1/2+1/2))=1/2
that amp is only 2ohm stable bridged, so you could not do the above
If you wire in series it would give you a 8 ohm impedance which would require a much bigger amp
If you haven't bought these yet and want 2 subs, I would suggest going with a 4 ohm DVC sub
like the alpine swr 1224d (Same sub, different impedance)
then you could wire that to a 1 ohm impedance and will have a easier time finding amps that will be stable at that level
I would not use the amp you have mentioned
oh and this is in the wrong section (classifieds)
WRONG!! actually u can wire 2 dual 2ohm subs and get 2ohms
Ok. Both subs together will be 4ohms put together. 2ohms a sub. I want to get a wire configuratinh can get each sub down to 1ohm a sub. So 2ohms a pair. I haunt decided what amp to get. So could I maybe get some advice on what amp I should get and how I should wire it. Sand I don't have slot of money. And I really want type r..........help
all u got to do is hooked up the 1 positive and one negative from different vc's
then the other positive and negative run to the amp
that would make your sub 4 ohms
then do it with the other sub and then tie both subs together and u have 2 ohms
when u tie them together they drop in half not double
sundownmaalpine
MuStAnG
sundownmaalpine
southern indiana
treadburner
Mike Mccabe
