Any Recomendations
mxsi64
I have posted before but not as explicit as now, can you recomend an amp to power up 3 600w pioneer (120RMS) not over 100 bucks that I can buy at ebay, also I have heard that a class D will be perfect but I do not know WTF is that how you get a mono amp to power 3 subs, I mean if your subs are 3X600W you will have to buy a 1800w mono amp to get the max out of it, and also what accesories you will need to do that, sorry to ask to much I am new at this:confused:
Before anyone can help you, you need to state how many ohms the voice coils are in your subs and if they are single/dual voice coils.
The problem with 3 subs is that you are either going to run above the impedance that an amp will put out its highest power which will be less efficient (use less power from amp), or lower than it's stable rating which can damage the amp. Or you'll have to get an amp with a regulated power supply so the amp can put out its full potential in a given range of resistance, however those amps are more expensive.
what model subwoofers, and the rest is simple...make sure you are looking at rms ratings only
OK here are the specs Pioneer TS W251R :
10" Single 4 ohm Subwoofer
IMPP Composite Cone
Large Strontium Magnet
Extended Excursion Design
4-Layer, Long Voice Coil Design
Extended Pole Yoke
Large Binding Posts Compatible with Heavy Gauge Wire
Power Handling:
120 Watts RMS
600 Watts Peak
Frequency Response: 20Hz - 4.5kHz
Sensitivity: 90dB
4 Ohm Impedance
25 oz. Magnet
No Dual Voice Coil
What about this amp???
http://cgi.ebay.com/NEW-1200-WATT-PRO-CAR-AUDIO-AMP-NONE-NICER-W-WARRANTY_W0QQitemZ250221297989QQihZ015QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
OK here are the specs Pioneer TS W251R :10" Single 4 ohm Subwoofer
IMPP Composite Cone
Extended Pole Yoke
Power Handling:
120 Watts RMS
600 Watts Peak
Sensitivity: 90dB
4 Ohm Impedance
25 oz. Magnet
No Dual Voice Coil
you need an amp that does 360watts @ 1.3333ohm mono
So you think It would be better if I get 4 subs (they have more where I buy these for 10 bucks each, but they have Visonik and MA audo brands 12s and 15s 900w 600w), because now a coworker here is selling me 2 jensen subs, I do not know the model right now but I think they have to be the same 4 Ohm than the others to work all right?
So you think It would be better if I get 4 subs (they have more where I buy these for 10 bucks each, but they have Visonik and MA audo brands 12s and 15s 900w 600w, because now a coworker here is selling me 2 jensen subs, I do not know the model right now but I think they have to be the same 4 Ohm than the others to work all right?
don't mix and match subs
When you have time can you do me the favor to look at this ones that I can buy and give me your opinion of the three best amps here mentioned in order wich one will be better, also tell me if the ones that you told me will get these 3 to the max, sorry for the time spend here, I know I know is a lot of text.
KICKER ZX400.1 CAR AUDIO 400W CLASS D AMPLIFIER AMP
http://cgi.ebay.com/KICKER-ZX400-1-CAR-AUDIO-400W-CLASS-D-AMPLIFIER-AMP_W0QQitemZ310028473720QQihZ021QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
KENWOOD KAC-8103D 1000W MONO BLOCK CAR AMPLIFIER AMP
http://cgi.ebay.com/KENWOOD-KAC-8103D-1000W-MONO-BLOCK-CAR-AMPLIFIER-AMP_W0QQitemZ330216017514QQihZ014QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
MA AUDIO M1900XE 1000 WATT MONO CAR AMPLIFIER SUB AMP
http://cgi.ebay.com/MA-AUDIO-M1900XE-1000-WATT-MONO-CAR-AMPLIFIER-SUB-AMP_W0QQitemZ300202247821QQihZ020QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
SONY XPLOD MONO BLOCK 1CH CAR AUDIO AMPLIFIER 1100W AMP
http://cgi.ebay.com/SONY-XPLOD-MONO-BLOCK-1CH-CAR-AUDIO-AMPLIFIER-1100W-AMP_W0QQitemZ220208841231QQihZ012QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
NEW PIONEER GM-7300M CAR AUDIO MONO AMPLIFIER MONOBLOCK
http://cgi.ebay.com/NEW-PIONEER-GM-7300M-CAR-AUDIO-MONO-AMPLIFIER-MONOBLOCK_W0QQitemZ280206053958QQihZ018QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
mxsi64
mxsi64
El paso, TX
mxsi64
