any idea for a completely enclosed sub?
OP,
I'd rather build a 4th order than try to take on a properly designed T-line any day. Not saying a T-line isn't better, but takes up a lot of space. A properly designed 4th or 6th order will keep the sub protected from objects in the trunk and have very good output up to about 60hz. They can get pretty big, but not as complex/expensive to build. You also could build an up or down firing regular ported box with port up or to the side....//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
All you ever wanted to know about boxes: Car Audio Subwoofer Enclosures
Or 8th order, but as you go adding more ports the tuning gets harder. 4th order BP is a good choice for protecting the sub. But you do need it custom designed for your sub, and not all subs work well in that type of box.
rockunlimited2
rockunlimited2
omaha
duanebro
