Any Heavy Equipment Operators in here?
have usedback hoe ford & cat
track hoe cat
track loader cat
all dozers are cat
d5h dozer
d6n dozer
d8k dozer
d9n dozer
d9r dozer
d10r dozer
d11n dozer
cat graters
14g grater
14h grater
volvo 12ft grater
834d rubber tire dozer
992g rubber tire dozer
loader
it18 cat
628 john deere
992g loader cat
992h loader cat
994b loader cat
haul trucks cat
777b
777d
789b
789c
793b
793d
693 cat scaper water truckes
ford brush hogs 5-6ft
john deere hogs 5-6ft
10 ton rollers
6 ton high pack rollers
24ft end dump trucks
24ft dump trucks(18ft beds) 10sp super10 9spd over 13sp 18 sp and automatics hp was 285hp-625hp
mack lube trucks(oil service trucks)
i think that is a starter list of most of the equipment i have worked with on or around
forgot to at 25 ton over head crane
You sound like the guy to talk to. I have an opportunity to do some snow removal work up in Vail this year ( I know one of the local county maintenance officials). It's seasonal contract work and hard to get into the lower floor on. I also have the financial backing to purchase a used wheeled loader for the work.
I want to buy a 2-3 year old CAT 928G. What should I look for as far as wear points?
look into all maint records if they have of them and if they have had oil samples done on them.
you can go to cat and have samples run for you to test all fluids runs about $20-$40 per sample last i heard. but they will tell you alot about the care of the equipment. can take up to 2 weeks some times
best thing to look at is all greaseable pionts lift, turn and rear axle tilt area. double check all u joints should be 5-6 of them. check all hyd. cyl. seals for cracks or leaks
take some one with you and drop the bucket to floor level and lift front end into the air about 1-2" ( lift and set on the ground to check every point) that will let you check out all of your front lift/ tilt pins. also check center piviot pins at the same time there should be no play in any pins/ piviots. if there is problames are soon to be there.
when you have done that lift the bucket and shake the steering wheel about 1/4 turn each way to make the loader shake side to side. this will let you check for center piviot wear and out of shim bucket and lift arms. You should have a 1/16-1/8 play that is fine
on some of the g loader the bottem bucket pins are oil filled make sure that if they are to double check inner and outer seals(not a cheap fix)
look for any out of place rust and any i mean any cracks on the entire loader.
do a all over check like you would do on any car.
sorry to ramble if i lost you at all sent me a eamail and i will try ro make sure you understand what you will need to look at/for
ben
look into all maint records if they have of them and if they have had oil samples done on them.you can go to cat and have samples run for you to test all fluids runs about $20-$40 per sample last i heard. but they will tell you alot about the care of the equipment. can take up to 2 weeks some times
ben
Thanks Ben!
I'm going to copy/paste and print and take with me when I go out looking. You've been a real help and I appreciate it.
Have ran ... Volvo L220F and L350F loader, G976 grader, and E360C excavator ... and a ton of Cat equipment, namely the 797. Used to mine ... so much like Ben I have driven a lot.
Locomotive engineer/ yardmaster.
Yeah? Me too......here's my company vehicle....
BoomBoomBoy
Supreme Veined Member
BoomBoomBoy
Everywhere, USA
mavster
