any good/useful??
WELL, I HAVE HEARD OF RIOT BUT NO EXPERIENCE... BUT IT IS A MONO AMP, WHICH MEANS ITS A SUB(S) AMP... i would not try it seeming since quarts are mids and highs and your subs are lows, not to mention that when you hook speakers up, in order to get a certain power rating you need to figure your ohm loadage from series/parallel hook ups.. if you get it, let me know how the amp works on your subs
Aint it strange how a lot of these lower end amps always pose the amp so as to NOT show the fuses. I have delt with Boss stuff in the past. True you could do worse but dont let the exaggerated numbers fool you, that amp wont do 3000 watts.
Its a mono block and you can hook up as many speakers/subs to it as long as you dont exceed the ohm load recommendations/specs. I would not however, recommend mismatching them, make sure you use all the same speakers/subs.
Mixophrenia
Mixophrenia
Columbus, OH
Focused84
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
