rfkjustin
Currently have a prime 750. RMS is 500 at 2ohm. Any other amps around the same size but higher RMS?
Multi channel or single class d?Those are only 300RMS. I've only seen massive audio e3 and thats cutting it close
Sorry for the misunderstanding, but less than 10-12inches in LENGTH. some manufacturers have those mixed. That was my bad6 inches wide. M1d5 inches wide. DM1000
7 inches wide. https://www.sonicelectronix.com/lp/pla-monoblock-amplifiers/jad12001?utm_source=google&utm_medium=cpc&utm_campaign=PLA&affiliate=googpla&scid=scplp3611170&sc_intid=40252&adtype=pla_with_promotion&lsft=adtypela_with_promotion&gclid=CI2y2uuLyNECFce4wAodOfgPKw
Class D mono or AB depending on its reviews.Multi channel or single class d?
JBL GTX 500 is a class d 500 watt amp (supposedly).
You can't really get much more power then that unless you go brazillian which the size will not fit behind a radio or install space but can be fit in a space smaller then most amps.
Sent from my ONE A2005 using Tapatalk
