Any body ever seen this gound zero 22,000watt rms amp?
drumman8524
http://www.ground-zero-audio.com/english/08_pa220000spl.htm
This thing is insane Plutonium GZPA 2.20000SPL, here are the specs:
SPL competition amplifier
1 x 9600 / 16600 WRMS @ 4 / 2 Ohm (14,4 V, 1% THD)
1 x 10000 / 19600 WRMS @ 4 / 2 Ohm (18 V, 1% THD)
1 x 22000 WRMS @ 2 Ohm (18 V, 10% THD)
lowpass 35 - 250 Hz
subsonic 10 - 50 Hz
bass boost 0 - 9 dB (30 - 90 Hz)
phaseshift 0 - 180°
RCA (stereo): 1 x In, 1 x Out
linked to 2 Ohm
18 Volt stable
twelvefold power supply
bass remote incl. 5 m / 16.4' cable
This is quite possibly the most powerful amp ive even seen
And this subwoofer is insane too Ground zero Plutonium GZPW 18SPL:
diameter: 46 cm / 18"
power handling: 10000 WRMS
impedance: 2 x 1 Ohm
voice coil: 100 mm / 4" flat wire
excursion: X max. 35 mm / 1.39"
resonance frequency: 34 Hz
SPL 2.83 V/m: 95,1 dB
additional: VOXR high SPL surround
quad centering
paper- glassfiber- kevlar con
http://www.ground-zero-audio.com/english/05_pw18spl.htm
One of my friends back in 2003 used to have a Ground Zero Nuclear 10" subwoofer...and i remember i had 2 audiobahn 15" subwoofers, can't remember which series since it's been a while and his 1 10" gound zero was probably 2 to 3 times as loud as my two 15's
GZ has a history that relates to TC Sounds, hence the basket. And yes, the GZ Nuclear was arguably the first 'supersub' ever made. They were quite the envy of people on this very board when they were new.
I know squat about the amp, their current stuff is all European based (so far as I know) and is alot more popular there than here. GZ USA went under several years ago.
where are you getting GZ stuff here in the states?
really i dont know of a place to get it here anymore....you used to be able to like i said but that was back in 03 when me and my friends were able to get their stuff im not sure anymore....and i know they were associated with tc sounds at one point
read where it says in 1997 on this page below...
http://www.ground-zero-audio.com/english/01_gz.htm
but now tc is even out of business
drumman8524
drumman8524
Mooresville, NC
Supergumby5000
