any amp experts can explain what these mean?
i have an amp with no manual (performance teknique icbm 779). surely not great, but it's what i have right now.
can anyone give me a rundown on what these amp settings listed below do? or point me to a reference where i can learn about each?
the amp has the following settings, can anyone explain these and recommend settings?
i am using the amp to run two 10 inch 4ohm DVC subwoofers.
Input Select switch: [Low Level / High Level]
Bass EQ dial: 0 - 18db
HPF dial: 50Hz - 1KHz
XOver switch: [HPF / Full / LPF]
LPF dial: 30 - 500Hz
Subsonic dial: 10Hz - 100Hz
Level dial: 6V - 0.2V
i've tried researching, but really all i find is how to "set the gain", but this amp doesn't have anything marked "gain", so i'm pretty lost.
will be a couple more days til i have my enclosures installed, so not quite ready to play around, but i'd really like to learn about this stuff.
gain is the level dial on your amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Input Select switch: [Low Level / High Level] signal inputs, high = speaker level, low= RCA
Bass EQ dial: 0 - 18db Bass Boost, usually at 45hz
HPF dial: 50Hz - 1KHz X over for tweeters or components
XOver switch: [HPF / Full / LPF] X over selector, high pass/full range/low pass. low pass is for subs
LPF dial: 30 - 500Hz X over for subs. set it around 80
Subsonic dial: 10Hz - 100Hz X over for low lows to subs, set it around 20
Level dial: 6V - 0.2V gain
Input Select switch: [Low Level / High Level] (i think these are the rcas)
Bass EQ dial: 0 - 18db (bass eq, only use it if the bass is seriously lacking)
HPF dial: 50Hz - 1KHz (dont worry about that one dont use it on the sub)
XOver switch: [HPF / Full / LPF] (low pass for subwoofer use)
LPF dial: 30 - 500Hz (usually set anywhere from 100-200hz)
Subsonic dial: 10Hz - 100Hz (if your using a ported box use this to protect the sub from over excursion)
Level dial: 6V - 0.2V (gain)
QUOTE]
jono_s
jono_s
Fort McMurary, AB
boomzilla
vegang
vegang
