Another Noob Question HELP!
  • 2
culp7
So i've finally seen the light and relized that I would much rather run a 15" Kicker L7 or DC lv.3or4 over two kenwood 12's anyday.... So that brings me to my question:
If i'm running one 15" and i listen to rap, how many cubes should i build my box to and what tuning?
Also, W/ a kicker L7 or DC lv3or4 (depending on quote) What amp would you guys recommend me running?
Thanks!
Dude, the companies websites will have enclosure recommendations.
15" L7 - 3 - 6 cubes
15" Level 3 - 3 cubes
15" Level 4 - 3 - 4 cubes
It took me less than a minute to find this information. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Now, on to amplifiers.
Level 3 (2 ohm dvc) - Diamond D3600.1, Cadence ZRS-2002, etc...
Level 4 (2 ohm dvc) - Audioque AQ1200D, Sundown SAZ-1000D, MB Quart DSC1000.1, etc...
L7 (2 ohm dvc) - same as Level 4
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
524
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
culp7
culp7
Andover, KS
misfit138
    May 16, 2024
    May 16, 2024
