Another NEWB Needs HELP
mdsheely
Okay here is the problem, I was just given two Audiobahn AW1206q subs, dual 4 ohm voice coils, rms is rate from 50-1100? Attached to the sealed box the subs came in is a rockford fosgate punch series 4004 amp. The amp 50 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms)
200 watts RMS x 2 at 4 ohms (4-ohm stable in bridged mode).
What is the best configuration for the most output, without destroying the amp?
What is the real RMS on these subs. Am I going to be able to make it work?
Keep in mind this is going into a 2007 ext cab chevy silverado. So I dont need crazy output, just some bump, hopefully it will sound okay. Thanks in advance.
Oh yeah, I know audiobahn is generally thought of as an spl sub, but IT WAS FREE!!
Okay here is the problem, I was just given two Audiobahn AW1206q subs, dual 4 ohm voice coils, rms is rate from 50-1100? Attached to the sealed box the subs came in is a rockford fosgate punch series 4004 amp. The amp 50 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms)200 watts RMS x 2 at 4 ohms (4-ohm stable in bridged mode).
HAHAHAHAHAHAHAHAAHHA
mdsheely
mdsheely
Indianapolis,IN
mdsheely
