So where do you get 2600 watt amp from?
2600W Nitro 2 CHANNEL AMP
BMW-488
Price Reduced, normally $299, now only $249
Product Description:
*2600 watts, 2-channel bridgeable amplifier
RMS Power (4 ohms) 200 watts x 2 channels
RMS Power (2 ohms) 400 watts x 2 channels
Bridged RMS Power 800 watts x 1
* super high fidelity sound output
* wired bass remote level control included (see other pictures)
* built-in full crossover
* variable low-pass filter: 30-250Hz
* variable high-pass filter: 50-1,000Hz
* variable bass boost: 0-18dB
* variable gain/level control
* frequency response: 20Hz - 30kHz
* regulated MOSFET power supply
* mono bridgeable and stable at 4 ohms
* soft-delayed remote turn-on
* high-level and low-level inputs (speaker/RCA)
* 45 angled speaker and power supply connectors for easy installation
* adjustable input sensitivity
* gold plated RCA connectors
* gold plated power and speaker terminals
* 2-8 ohm load capacity
* 3-way protection with LED indicator
* dual color power and protection LED indicators
* 1-year Manufacturer's warranty
Amplifier Specifications:
Amplifier Class N/A
Number of Channels 2
Peak Power Output 2600 watts
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.03%
Speaker Level Inputs Yes
Built-in Crossover Yes - HP / LP
High-Pass Crossover Frequency 50 - 1 k Hz
Low-Pass Crossover Frequency 30 - 250 Hz
Subsonic Filter
Signal-to-Noise Ratio 95 dB
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fuse Rating 80A
