DrAndews
I've recently installed 6 Solobaric L7 15" in my 2011 Yukon (Backstory as to why I've done this)
I took my old subs. (A pair of l7 12" 2008 model's) and a 2800 Watt Nitro Amp out of my car and brought it inside .. of.. my.. house.. set it infront my my home TV and wired it to a Yellow Top Optima Battery with the intention of just trickle-Chargeing the battery at night.
Worked great the first "Night".. Day number 2 comes around.. Im so excited because its finally daytime and I get to crank that thing up and hopefully make my Roof shake without waking my kids. I Plop down in front of my amp. Grab those Connector Wire and slam them into the battery.. .... Sparks... Yup.. Backwards
Soo.. In my forever ignorant stupidity. I never put a Fuse on the actual cables.. (not yet at least)
The fuse to the amp Blew (80A) Ive replaced it.. It powers on just fine.. and Its not going into Protection mode.. It just wont play any sound.. I would throw it out and just buy a new one and not bother yall.. HOWEVER; (This is the part I need help with, Hope you've enjoyed the backstory)
Whenever I unplug the battery, the Next 1.5 seconds .. the subs sound awesome. They play, Everythings fine until the Amp uses the rest of the juice it has stored..
SOO!! Im wondering if Maby,, I've junked my Optima Battery ?? Or could this maby be a case of low power on the battery? I do not have a volt-meter, Or a trickle-Charger. If Someone is 50% positive this could be caused by low power Ill go buy a trickle-Charger and charge this thing up
Anything else I should try?
