Ok, I decided to replace the remote wire first and it made no difference so the grounds were probably the problem. I shaked the remote wires a little and everything started working. I think I need to tighten it a litte more (its in a difficult place to access).
Other then that, everything works fine....but there was a smell of something burning. Twice. Both times it was for like a minute. Its been a few days since the install and it didnt happend again, I am not sure if its the wires.
My wiring consists of a an inline fuse with a 200A fuse, 1/0 wire run up to a distro block from where I have 2 4gauge wire runs to, one to each amp. Then I have 4gauge wire to grounds as well. The distro block has one 60A and 80A fuse, as the amps requiere.
My only worry was joining different gauge remove wire. I had it done in a shop, so the wire from the radio was probably a gauge 18 but they didnt measure right and ended up the run with 2 feet of 22 gauge. I dont think its that important right?
Could the burn smell be from the cables? I did leave a small hole through the firewall that I need to patch up (where the 1/0 was run through). I couldnt locate the origin of the smell because it was very quick and dissipated immediatly.
Maybe I worry too much.
Aded an image because I was bored:
Yes, both grounds go to the same place, its a bolt under the seat that is directly connected to the chassis of the car.
