Ampliwhat??
My suggestion is save up a little and get a job before you blow your money on some bad/mediocre product from wall mart. Do as I did, and stick around for a few months untill you have enough money and information to make a wise purchase.
Take heed to that advice. You will be glad you did. It is alot better off then buying some walmart junk. Stay around and learn a few things.
Stick around and read up on this site. Lots of good and knowledgeable people on here. Don't look at the "shiny" stuff from Wally World. Do your research and save those penny's. You will enjoy a well thought out and planned system mucho more than a "buy it now 'cause its cheap" system. It takes time. I'm still building. But it will be worth the effort.
Good Luck!!
http://forums.caraudio.com/vb/showthread.php?t=113645 heres an awesome cd player for the price... it has only 1 preout tho. ull only need 1 the way it sounds. are u planning on getting a subwoofer? if so, what size are u looking for? 8,10,12,15... ect. most of the time you can get some AWESOME deals here on the forums. theres one guy on here selling 2 memphis pr 10's for 100 bux. talk to him. those are some awesome sub's. just get you some kind of decent/good amp off of ebay and put a link here so we can tell yay or nay on it.
Its good that you're ok admiting you're a rookie. This will give more people reason to help you out. Learn, learn, learn and save. If I had a dollar for every person I knew that regreted buying crap instead of waiting, I would be able to buy a new watch.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
'90 model Camry has the following:
Single DIN-chassis AM/FM radio (some with, some without cassette players)
3.5" speakers in odd little enclosures (with factory passive radiator!) in the dash. Cloth grills will be found immediately under the A/C vents on either end of the dashboard.
Don't try prying these grills off attempting to access the speakers - it won't help you and you're more likely than not to break the retainer tabs that hold those grills on.
It's kindof a complicated process getting at those speakers. Well, not complicated, but rather sortof involved. There's several screws and bolts that have to be removed to get those enclosures out then the speaker is removed from those to be replaced. I have a set of Crutchfield MasterSheets for the second-generation Camrys. I'll see can I dig it out and post a step-by-step for upgrading the factory speakers.
In the back dash (if equipped with rear speakers) is a pair of 5.25" speakers housed in pods underneath those rectangular covers that can be seen atop the deck surace. To remove these you have to carefully pry up an edge of that cover and get the pressure clips to let go. Unfortunately replacing the back speakers isn't a simple plug-n-play type of affair. They have squarish brackets that bolt into the pod they are housed in and no aftermarket speaker will match the opening. There are aftermarket adapters available if you wish to keep the OEM speaker size back there.
Like I said - I'll try and dig out that set of MasterSheets and post a step-by-step for you.
To answer your actual question - yes, you can benefit from upgrading from OEM stuff.
You won't need an amp (as in absolutely 'have to have') but depending on what kinda speakers you upgrade to your speakers may never realize their full potential without one.
Unless you get very involved with upgrading your tunes (and it becomes an addiction as all of us here can attest to) you shouldn't need an electrical system upgrade. But after the *bug* bites and you're well and truly sucked in you may in the future....//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
Have a look at the various stickied tutorials easily found in the forum index. Heaps of helpful tricks, tips, and general info to be found there.
Hope this helps somewhat and I'll be hunting those MasterSheets for ya. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
N3WB
N3WB
Lincolnton
Prowler573
