emmyedge
This seems to be a common issue that I have had over my past two cars I've owned plus the past two Amps that I have owned. I do not remember the brand and info on the last amplifier due to how long ago I had it, but I currently have a Pyramid PB918 2,000-Watt 2-Channel running two Sony Xplod 12 inch 1200w subs off of it. When they have been on for about a 1/2 hour or if they music is up too loud the Amp goes into protection mode. This happened with my last amp as well as my last car I owned. I currently own a 09 Jetta TDI running a basic 12v battery, which is brand new plus a brand new alternator. (I will note that after installing my brand new battery, the fuse that is connected to the battery wire to the amp actually caught fire after the amplifier did not, for once, go into power protection mode, I have since replaced that fuse holder and a 60amp fuse) I have the settings on the Amp basically as low as they can possibly go without turning everything off but that didn't seem to help. It seems if I actually want the bass to hit the amp is going to go into protection mode. Ground is fine, all wires are fine. (trust me, I've made sure of this several times) I just need a suggestion of what to do. Have run both amp and subs, with settings applied to a much higher point, in my boyfriends truck and have not come across this issue. Why does it do this in just my cars? (p.s. old car was a 2000 nissan altima)
