Amp
This little amp would be perfect for you, and you can use it on a new head unit if you buy one in the future.
How would i hook up the RCA cables when I'm pretty sure my head unit doesn't have plugs for them
---------- Post added at 11:37 PM ---------- Previous post was at 11:36 PM ----------
Yea I'd do the same prolly won't get much better from a deck unless amped. Especially with stock speakers
I dont have stock speakers the only thing stock is my head unit
Ok. Biggest issues with changing the stock speakers is 1 not sealed properly and 2 higher impedance so they don't get much power which can make them not sound as loud
I'm pretty sure i did i right cause the sound quality is good and it can get loud just not loud enough if i turn my subs up alot
You don't use the RCA cables with a stock head unit. This amplifier has high level inputs that are wired directly to the speaker leads.
. So the wires just connect to the speaker wire behind the head unit or do I have to send wire all the way to each speaker?
You can connect both the amplifier input wires and the output wires behind the head unit. It's doing the exact same thing as an LOC, except inside the amp and you don't have to adjust it.
Dan123196
Dan123196
Boston ma
trumpet
