Amp wont power?
bopo668
JerryRig
i used my multi meter and its only reading 2.7 volts at the amp.does that mean there is a split some where or bad fuse holder i tried two different fuses so its not the fuses i have a good ground what else could it be.aslo if its remo is there a way to hook it to the power wire so it says its on, im just having a bad day with my stuff
its 12.5 before and after the fuse holder. and at the amp it reads 12.5 but when i put the remote wire in it jumps to 2.5 is that just because the glass fuse is blow but not all the way and wont hold power
all right i got a new fuse and fuse holder its the one that takes U shaped fuses not glass ones. all the wires measure 13.9 going in to the amp be four the amp. but when i turn my amp on with a toggle switch that goes from the power wire to the remote the amp turns off and goes to a 2.5 draw??? what could be doing this it does it with eveyones amps so its not my amp could it be bad ground
bopo668
JerryRig
bopo668
tex
bopo668
