Dallas Cowboys
Is this amp good or no good? I bought it and it is the wrong application for my woofer.US AMPS
AX-1000DE AMPLIFIER
NEW
1000 WATTS BRIDGED @ 1 OHM
LOW RESERVE
Discover the secret of car audio professionals, championship winners and serious sound enthusiasts. High performance listeners agree - the best systems are built on the rock solid foundation of U.S. Amps. For 2 decades, U.S. Amps has defined the standard of amplifier quality and power. Designed and hand-crafted in California USA, U.S.Amps are the finest car amplifiers ever built. No other company offers such a wide range of high quality purpose-designed amplifiers.
The AX Series of amplifiers have an almost indestructible power supply to provide max power while maintaining the utmost sound quality. They are under-rated, which means they'll pump out more actual sound power than the RMS power-rating indicates. These amps use high mass, hand-wound toroid cores that pass massive amounts of current, allowing very serious drivers to be used with them. Expect great sound quality from these amps, with very low THD (Total Harmonic Distortion) and a very high dampening factor.
Here are a few specs on the Amplifier:
1000 watts x 1 @ 1ohm
700 watts x 1 @ 2 ohms
350 watts x 1 @ 4 ohms
# 90% Efficiency at clipping
# Master / slave Input Drive capable
# Dual Power Toroids
# Variable Low-Pass (LP) Crossover
# Subsonic Filter
# Non-computerized SAT
# Remote Bass Gain Control Included
# S/N >86 dB
# Damping Factor >250
Amp Dimensions:
Dimensions: 16.1" L x 11" W x 2.7" H
AX-1000DE AMPLIFIER
NEW
LOW RESERVE
# Subsonic Filter
# S/N >86 dB
Amp Dimensions:
