Winter_C
Teh Pinto Driver
Ok, so i got my meter, set it at ACV 200 right? put + in + output on amp and - on - terminal on amp? set my HU, and put on 45hz test tone like tutorial said....and i begain to adjust gain, and i am up in like 50-60 volt area? and the tutorial said
Voltage of the output = sqrt(RMS Power X impedance of the speaker)
I have a KX1200.1 which does 1200 RMS at 1 ohm, 600 RMS at 2 ohm, and 300 RMS at 4 ohm
My subs are 12" p3's which are 500 RMS and impedance is dual 4 ohm
This is where i am confused...that formula would be voltage= SQRT(30084ohm) for 4 ohm right? which is 34.64...
And if i did 1 ohm it would be? Voltage= SQRT(1200*1)? which is 34.64
And if 69.28 is right, Which I am sure that is the outcome of that, my amp with gain maxed out is only like ~61 volts...And when doing this, the RMS on my subs are 500 each, so do i do 1k? making it be Voltage=SQRT(1000*1) which is only like 31.62 and that means my gain knob would be turned down less than it would be at 4 ohms? and 31 volts on my amp is like 1/4 turn....that doesnt make any sense to me, and from like 5/8 to max, my voltage is like 60ish...is that right?
