Amp Trouble
  • 4
a battery just for your amp is ideal IF you have a proper alt to supply your reg battery and a battery for your system. you just throw in a battery and use the pos battery terminal to your amp and ground the battery to any location wont help. that battery will be bead in an hour of playing without it being able to re supply the power taken from the amp.
you could run the neg power cable from amp to the original batteries ground or batteries ground location and see if it helps.
could i use the positive wire? if i cut it in half? or will it make a difference
I wires the sub and checked it. It is at 2ohm and the speakers are at 2.5 from what the manual said
920
6
89
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
264
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
285
knowlton
knowlton
Wv
Boomin_tahoe
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
