Amp that pushes 1200w at 1 ohm?
You couldn't really go wrong with the sundown or the audioque however the sundown will give you slightly more output power. It may not even make for an audible difference but most people feel better knowing they have a little extra juice on tap. You could also get an ED nine.1 and have a matching setup. Any of those amps should do what you want
Yeah, the MBQuart DSC1500 is a great amp, and someone just posted the internals of it and it's very nicely built. The AQ1200D is a nice amp as well, can't go wrong with it, as is the SAE-1200. Don't be set on buying an amp that puts out EXACTLY 1200w RMS - a more realistic range should be 1000w-1500w since: there will be very little audible between amps within this range, amps have quite a bit of variation from unit to unit, and your subs will be able to handle more than their rated power as long as everything is installed well.
SPLmatic
word
SPLmatic
Lincoln, NE
DarkScorpion
