Amp Suggestions to Power 4 DD1508's?
Memphis 4kw
Sundown 3000
Kicker KX/ZX2500.1 if you want to risk wiring it to 1 ohm
Autotek MM3000.1
Autotek MM4000.1
IA 40.1
Pair of IA 20.1 strapped to 1 ohm
Okay, I suppose I should be more specific. I would like to spend under 600 dollars on the amp, how about then?
Also, could somone refer me to a website that explains the different aspects of amps? Another thought that came to mind.. Is my factory alt gonna be able to take this kindof setup?
Most likely absolutely not.
For under $600 - Autotek mm3000.1 or mm4000.1.
Or I can sell you my Stetsom 2k6d. I clamped it on Saturday doing 2925 watts at 0.95 ohm.
I've only got one batt. I suppose I could get another but couldn't I just use a capacitor? I think that's what it's called right? W/e the thing is that holds charge.
Well, will a factory battery and alt be able to take just 2 DD1508's and a 2000wrms amp? I am pretty sure it'd be fine, but I'm no expert. Also, how much would another battery run me?
CoKaine
CoKaine
Madison WI
CoKaine
