Amp suggestions for rainbows (yes, another one)
swangandbang
There's a lot of posts reccomending subs for slc265s, but I'm looking for a 4 channel amp that will run both my:
slc 230 set (80rms)
sl 6x9s (100rms)
I was told that I should get a 4x100@4ohms, but I can't seem to find some "reputable" brands that will do this for under $200.
Any suggestions?
In my experiences if an amp puts out the amt. of rms wattage you need then it doesnt matter what brand as long as it doesnt go into protect or some whak shizzle like that. I ran a dual amp and it worked flawless, audiobahn amp and it was fine for what i needed it for, and cali. pro. this one was messed up and i got it for free so i didnt mess with it. But if you want a good name on your amp you are gunna have to buy that name for about $300
problem is that I can't bridge two, I have to keep it with one because I was told you should only put 2 amps on your battery. I'm fine with buying it off of ebay, so what are some semi-reputable brands then? I wish hifonics made a 4x100@4 ohm, but they don't.
swangandbang
swangandbang
Austin,TX
FoxPro5
