In the near future, I will be adding a sound system.. to my jetski. I realize and respect that this is a caraudio forum, I just had no where else to turn, and the systems are pretty similiar.. I just had a few questions.
I want to run some small full range speakers mounted in the mirror casing on my jetski, as you might have guessed, not leaving me much space. There is room for either One 3" 60peak/30rms 4 OHM on each side, or Two maybe Three 2" 30peak/15 rms 8 OHM. Which do you think would be best??
For a marine amplifier, if I had the Two 2" on each side, should I get a 120 watt dual channel (60 watts per channel) or 60 watt dual channel (30 each channel) ??
Also, how much time would a system like this run for on a stand-alone 12v??
Don't be afraid to offer a differnet idea!
Thanks a lot.
--Pike
Thanks a lot.
--Pike
