amp setups
beatthis27
ok im new to these forums but i used to be heavy in systems, changed setups every month in my cars, but i been out of the "scene" for 2 years and its like i forgot everything... i got 2 setups i traded around for and just wanted to know the best way to set them
first the one actually in my car at this point
i got 2 memphis audio PR 10's in a slot(middle) ported box with a P3001 rockford amp on the amp what should the hz be set at and where should the gain be at how should i set all this thanks
now the second
i have a older tri MTX blue thunder 10's box, ive had prolly 4 of these in my lifetime and love them, the amp i have for these that my friend had on them is a older rockford punch 201s 600 watt amp, now it only has a gain knob and a rocker switch that has 3 spots one says 0db one says +6db and the other says +12db which position should the rocker be at and where should gain be at for this setup thanks so much for any help //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
beatthis27
beatthis27
chattanooga, tn
beatthis27
