amp selection acording to ohms
is there an advantage or going with the one that puts out 1200 @ 4ohm
than the one that puts out same @1 ohm?
would the amp that puts it out @ 4ohm be more true power instead of the one that puts it out @1ohm in other words over inflated numbers vs true output
PA amps
BAMF 2000/1D 1200 @ 1 Ohm
other is
BAMF 4000/1D 1200 @ 4 Ohm
and yeah yeah there power acoustik amps apparently not that great of an amp
MOFO-12
* 2400 watts power handling
* 1200 Watts RMS
* 270 oz . magnet
* 3¡± BASV/Kapton Hybrid 18 AWG Voice Coil
* SPL 90 dB
* Fs: 36.7 Hz
* Vas: 0.73 cu.ft.
* Qms: 5.34 ? Qes: 0.36 ? Qts: 0.3363
* Xmax: 0.7"
* Sealed box: N/A
* Ported box: 2.4 cu..Ft.
* Tuning: 40 Hz
* Port size: 3¡± (dia)x 6.75¡± (length)
* # of ports: 2
* Mounting Depth: 6.75¡±
MOFO-12
* 1200 Watts RMS
* 270 oz . magnet
* SPL 90 dB
* Fs: 36.7 Hz
* Vas: 0.73 cu.ft.
* Xmax: 0.7"
* Sealed box: N/A
* Tuning: 40 Hz
* # of ports: 2
rammstein
rammstein
AZ
rammstein
vegang
vegang
