I have 2 JL audio 500/1's and a 300/4. 1 500/1 is 9/10 cosmetic and works flawlessly. The other 500/1 does not work and is prolly 7/10 cosmetically (big scratch on it). will post pics and specs tomorrow. Im asking $225 for the working 500/1, $225 for the 300/4 and $100 for the non working 500/1.
I have 2 image dynamic amps Q600.1 and Q450.4. Im asking $500 for the pair or $275 each.
Specs:
Q600.1
POWER @ 14.4V
RMS AT 4 Ohm , STEREO = 250 x 1
RMS AT 2 Ohm , STEREO = 400 x 1
RMS AT 1 Ohm , STEREO = 600W X 1
S/N RATIO @ rated power > 98dB
INPUT SENSITIVITY = 0.15V ~ 6.0V
INPUT IMPEDENCE = 20 KOhm
DAMPING FACTOR @ 50 Hz = > 100 @ 2 ohms
FUSE RATING = 40A x2
WIDTH = 8.5 / 222mm
HEIGHT = 2.125 / 54mm
LENGTH 13.75 / 349mm
AND
Q450.4
POWER @ 14.4V
RMS AT 4 Ohm , STEREO = 75 x4
RMS AT 2 Ohm , STEREO = 125 x 4
RMS AT 1 Ohm , STEREO = 250 x 2
S/N RATIO @ rated power > 100dB
THD+N typical/rated power = 0.05% /
CHANNEL SEPARATION = >65dB
INPUT SENSITIVITY = 0.15V ~ 5.0mV
WIDTH = 8.5 / 222mm
see pics here. http://www.diymobileaudio.com/forum/classifieds/71876-wtt-2-id-amps-1-jl-amp.html
Specs:
Q600.1
POWER @ 14.4V
WIDTH = 8.5 / 222mm
AND
Q450.4
POWER @ 14.4V
WIDTH = 8.5 / 222mm
