How to convert/shrink MTS or M2TS files to DVD for burning?
If you have dozens of M2TS files, you may want to convert or shrink all these M2TS files to DVD and you may don’t like a time-consuming, multi-step process for your M2TS to DVD conversion or M2TS to DVD compression. Sometimes you may want to burn these MTS files to DVD.
Part one: how to convert MTS or M2TS files to DVD?
Don’t lose time, I will recommend a quicker and easier way to convert M2TS files to DVD with smaller size via Moyea MTS/M2TS Converter.
Free download this MTS/M2TS Converter here which can help you convert MTS or M2TS to DVD with good output quality, install and run it.
Step 1: Click “Add” to import all your M2TS files.
Step 2: Click the drop-down list of “Format” to select an output format, you have the choice to select DVD PAL or NTSC.
Step 3: Click the folder icon of “Output” to specify where to load the output files
Step 4: Click “Settings” button to shrink or compress file size of M2TS videos.
Please pay attention to the following image, when you click “Settings” button, it will pop up immediately, in which all the video and audio parameters like video or audio codes, bit rate, frame rate, size, sample rate, channels can be changeable. “But what should you do to shrink or compress the file size of M2TS files?” you may ask. In fact, it is just like a piece of cake, all you need to do is adjusting the parameters to be smaller, and then the file size will be compressed correspondingly while conversion.
Step 5: Click “Convert” button to start M2TS to DVD conversion and file size shrinking.
Part two: How to burn MTS or M2TS files to DVD with free burning software?
Step 1: Free download ImgBurn program here, and load it.
Step 2: Switch to “Write” mode
Step 3: Insert Disc in Burner
Step 4: Select Image to burn
Step 5: Click “Write” button
If you have another alternative method to create CD/DVD with free software, just share with us.
Useful information should be shared with everyone, isn’t it?
