Amp recommendations?
killabee76
Ok, I bought the P2l-212 Rockford Fosgate Enclosure with the subwoofers. Here's the specs,
Subwoofer Size 12"
Voice Coil(s) Dual
Impedance (Per Voice Coil) 4 ohms
RMS Power Handling 250 watts
Total RMS Power Handling 500 watts
Peak Power Handling 500 watts
Total Peak Power Handling 1000 watts
Woofer Composition Thermoformed Polypropylene
Woofer Surround Poly-Foam
Sensitivity 86 dB
Frequency Response 26 - 250 Hz
Next is the amp. Tons of research and I still am lost as far as Ohm's, etc..... I'm looking for any recommendations from any of you of what would pair up good with these subwoofers. Mainly looking for a mono amp. Been looking at a few and was wondering if these would match up good?
http://www.amazon.com/Rockford-Fosgate-R500-1-500-Watt-Amplifier/dp/B001P86SMK/ref=cm_cr_pr_product_top
Amazon.com: MB Quart ONX1.1000D D-Class Amplifier 1 x 475 @ 4 OHMS, 1 x 750 @ 2 OHMS, 1 x 1000 @ 1 OHM: Electronics
Trying to stay around the $200 range
Any recommendations, links or info is greatly appreciated. Thanks
killabee76
killabee76
Cadillac, MI
trumpet
