Amp Recomendation
  • 2
Are you planning on getting a three way comps?
If it's a three way CDT comp get at least 100 rms x 2 amp to run the set. Depends on what model CDT your buying.
If it's a 4" coax on the dash and 6 1/2" 2 way in the doors,
that soundstream amp will be to weak for the CDT's, ok with the 4" coax. If i where you i will get a powerful 2 channel amp for the CDT comp and run the 4" speakers from the HU.
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
84
6
329
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
640
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
471
newt3no
Adire Guy
newt3no
NY
newt3no
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
