Amp Recomendation
  • Thread starter <ricweb>
  • Start date
  • Replies 2
  • Views 1K
  • 1
<ricweb>
Guest
I am thinking of uping the power on the mids and highs to 125 watt/channel. Any recommendations on how big my sub amp should be ?? I am only running a 10" in a sealed enclosure. I had always heard 3 times the power up front. Any suggestions ??
The sub I am running is a Alpine SWR-1040D, my current system has a Rockford 600a5 amp 50x4 and 200x1 at 2ohm.
Thank you, I did check the ground and and fuse holder wires and everthing is fine. All I did was swap amps and the previous Alpine pdx sounded...
63
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
266
Guest
