jj4475 10+ year member CarAudio.com Elite 1,785 2 ill Jan 3, 2007 #1 theres 2 rca inputs so do i have to run another set of rcas? my head unit has 2 or 3 more outputs. ive always only used one so not sure wat to do. thx for help Click to read more...
wesl56 10+ year member el sietes! 2,420 0 NoFl Jan 3, 2007 #2 one is for the front two channels, one is for the rear two.... are you gonna be running four speaks off this amp or bridging it?
P pboulos 10+ year member CarAudio.com Elite 1,468 0 Fl Jan 3, 2007 #3 if you want to keep fading capabilities then yea...
OP jj4475 10+ year member CarAudio.com Elite 1,785 2 ill Jan 3, 2007 Thread Starter #4 runing 1 dvc 4 ohm sub so bridging to each coil if that makes sence
wesl56 10+ year member el sietes! 2,420 0 NoFl Jan 3, 2007 #5 then run one set of RCAs to the amp, and use Y splitters to send the exact same signal to both sets of inputs....
OP jj4475 10+ year member CarAudio.com Elite 1,785 2 ill Jan 3, 2007 Thread Starter #6 ok wats the sum out for
wesl56 10+ year member el sietes! 2,420 0 NoFl Jan 4, 2007 #7 ok wats the sum out for Click to expand... if u wanna hook up another amp
