amp rack
snow96
PIMP
i did my first custom install this weekend......i made an amp rack for my 2 amps, crossover, and ground distro block...and i gotta say it looks **** good...i hope to get some pics up this weekend.....my next custom job will be a housing unit for my floor mounted screen...
here it is...
Uhh, all you did was mount the amps on a piece of wood //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
no i added carpet...feet on the bottom of the wood to make it sit at an angle....drilled holes...
I think it would look awesome if you put a baffle board across everything so all you saw was the top of the amps and not all the wires and stuff. That why you'd have a really clean install.
what is baffle board....don't laugh....
It's just a "fake floor" that goes over the amps and hides all the wires. All you do is cut out a section of the board so that just the top of the amp is shown. i'll try and find a pic of one.
Here's a pic with the baffle board removed
http://gallery.caraudio.com/pp/showphoto.php?photo=805&password=&sort=1&cat=500&page=1
And here's one with it on
http://gallery.caraudio.com/pp/showphoto.php?photo=807&password=&sort=1&cat=500&page=1
Notice how it hides all the wires and makes it look clean?
where can i get it from from...how much does it cost...
Well, you can make it out of pretty much any sheet of wood. I don't think it matters if it's MDF or not. You could probably use 5/8" particle board.
what about as far as covering it..can i use the same carpet that i used for the wood...or should i use something else...
snow96
PIMP
snow96
Texas
zephyr
