Pauly187
Hi guys new to the form! Had a question about my amp!
A little background of my set up
F150 extended cab stock electrical
5.4 cube box ported and tuned to 36hrz
Kicker l7 15 sub and box have replaced back seat and is firing up
Alpine deck with external amp running door speakers ( not problem)
Problem is sub amp hifonics brz1200 wired at 1ohm
This thing makes that l7 hit like crazy when the gains are all the way up but of corse the sub starts smelling and I shut it off right away. If I lower the gains below half the sub doesn't really hit but it no longer smells!
But this ***** cause I can't have the sub hitting like it should be!
I have the deck set at zero for bass
My question is if I upgrade to a REAL AMP kicker zx1000.1 will I be able to have the gains set low and have the sub hitting like it should be without the smell of the coils burning? //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif making clean power
Basically what I'm getting at I'm assuming I smell the sub because the hifonics amp is putting out dirty power and clipping
Will switching to kicker fix my problem!
Forgot to say I'm running 0 gage wire for power and ground monster cables from deck to amp RCA if any of that helps and stock electrical! Yellow top battery
