Amp power problem
lovick19
Ohio
Amp will not work unless the remote wire touches a strand of the 12v power wire could it be a blown fuse? I tried running new remote wires. It is not a bad amp because i hooked it up directly to another car and it works. Also when i have it hooked up the subs cut out sounds like not enough power is gettin to it
Hey man I hate to be that guy but this is the classifieds section only! I would post this on the forum section. since you are here I will give a little help tho. it wouldn't be a blown fuse on the amplifier itself but possibly the fuse that you have the remote wire ran to. checking that fuse to see if its blown would be what i would do first (it may not look blown but use a light test to check if it is)
Or
And the 2nd thread for the same thing. Just sayin
lovick19
lovick19
Ohio
toastyszosty
