valleyrider
So I am new to car audio but after some research I have decided on and purchased all the components for my bass system. I will be running an SQ2200 amp to a 12" SP4. I am almost finished building my box for it which is about 2.75 cu with 31hz tuning. I am keeping the stock head unit and will be using an LC2i attached to the factory subwoofer inputs to provide the signal to my amp, factory woofer is removed. I ran 1/0 KnuKoncepts ofc wire to amp location. This is a trunk build in my 2013 Hyundai Sonata 2.0t for those wondering.
My question is where to mount the amp. I can either mount the amp and LC2i to the top or rear of my box. Rear seems to look like the cleaner install location but I'm thinking top will provide better airflow for cooling. I prefer the cleaner look but I don't want to have overheating issues not knowing how much airflow is required to keep an amp cool. Which location is ideal for the amp and why?
Also when routing speaker wires from the amp into the box should I aim to avoid all the other wires to minimize interference? I'm trying to figure out idea wire routing based on which location I choose for install and which has the cleanest look.
Here is what the box is looking like so far, its a little rough I still have to put on some final touches and make it look a bit nicer.
