jflash
Wanted to continue my last thread but it was closed. http://www.caraudio.com/forums/wiring-electrical-installation-help/520589-about-grounding-rcas.html#post7707209
Since last January I have been running my brothers amp with no problems. He recently bought a sub and needed his amp back. I put my kicker back in with the same results. The amp is hooked up with a PAC 4 channel loc. 2 channels run to my amp for the components in the door, the other 2 run to the kicker. The component amp never goes out.
I can get the sub amp to work if I have the volume on the radio turned way up and bass level at -1 or if its down, I can turn the bass up to +6 to get it to work. But if the volume is below 5-6 it never kicks on.
I also tried the line level input on the amp with the same results.
