Amp Not Powering On After New HU Install
juckstapose
No, I Will Not Date You
I switched out my head units today - a swap from a Pioneer 860mp to a Pioneer 780mp. Since the harnesses were the same, I did not disconnect the battery. When I got everything all plugged back in, the HU works perfectly, but now my front amp is not getting power. It's not in protection mode, there is just no power //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I tried disconnecting and re-connecting the battery, and I checked to ensure that the remote turn on was properly connected. All connections on the harness are good. I tried disconnecting the RCA's and I turned the gains all the way down. No go.
Any ideas? Maybe a blown fuse? What can I do to test?
Thanks!
You sure the harnesses are exactly the same? My guess would be the remote is different pin on the new HU.
First things to check
-remote wire voltage @ headunit
-remote wire voltage @ amp
-power wire voltage @ battery
-power wire voltage @ amp
Few quick and easy checks
Ditto. Check Power wire voltage compared to the ground terminal and then to a ground of the car. They should be exactly the same.
Thanks for the help! I checked the harnesses pretty carefully and after a lot of frustration I found that the scotch lock I used to tap the ACC wire was ever so slightly loose. It was a little weird because I got power to one side after I took the fuses out of the amp to test and re-installed after they were both showing continuity.
So I think there were two issues... Anyhow, I am hooked up [somewhat] reliably and everything seems to be working now that it's all put back together - phew...
juckstapose
juckstapose
Baltimore, MD
juckstapose
