Amp making noise.
t-scene
I just installed my amp (mmats 1600.1) and the amp it's self makes a hissing noise with the power on. It also makes the same noise (but it changes pitch) in the subwoofer.
I tried unplugging my rcas and turning everything on and the noise is still there.
I couldn't set my gains with the DD1 because it would pick up dist. almost right away.
Any ideals on what could cause this?
I just installed my amp (mmats 1600.1) and the amp it's self makes a hissing noise with the power on. It also makes the same noise (but it changes pitch) in the subwoofer.I tried unplugging my rcas and turning everything on and the noise is still there.
You sure you have everything wired up correctly? 12V positive and ground, remote wire, speaker wires are where they should be? Is the amp brand new? What size wire are you running? Some more info is needed if you want more from us.
Yes everything wired correct. Sub is wired to 1 ohm. running knu 12g for sub and 4g for power and ground. The amp is brand new
Does it make the same noise with everything but remote, power, and ground disconnected? Pull your subs and RCA's off.
that an invitation to harrass you? //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
Hebe u do that anyway //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Do you have a 2nd amp you could hook up to make sure it isn't coming from the headunit?
See? That's better.
t-scene
t-scene
Abingdon VA
Montana
